I have made a stair by sketch, an u-shaped one. I do have som problems with the 3d modell. it will not show up correctly. I add som printscreens and you can see. You know what i have to do to fix this?
The first thing that comes to mind is that the view is cropped.
Don Ireland
Engineering Design Technician
Hi
Use one of the following methods may be your problem.:
1 - Reduce the thickness of the stairs.
2 - in the landing areas, with separate Split.
3 - In the Type Properties and Type Properties dialog box, click Run type in new window Stepped put option on the Underside Surface.
4-Monolithic type steps of change.
