How should I model a tennis court seating in Revit 2011 ? All ideas are much appreciated.
Thanks in advance.
Solved by alan.quinn. Go to Solution.
Some links which may be useful for stadium-type seating:
http://bimtroublemaker.blogspot.com/2010/01/december-2008-i-walked-out-of-au-with.html
http://www.revitcity.com/forums.php?action=viewthread&thread_id=6100
Thank you,
To add to Ryan's
Tennis seating as with any event seating varies. See the following links for possibilities I found on Autodesk Seek.
Auditorium Seating: http://seek.autodesk.com/search/seating?source=SearchBox&q=category%3Astd%3Aoc1%3A23.40.50.11.11
Bleachers: http://seek.autodesk.com/search/bleachers?source=SearchBox&viewMode=LIST&ftCombo=true
Hope this helps and thanks for posting,
