I have found missing values for the follow window type:
</WindowType>
<WindowType id="GSP12I" openingType="FixedWindow">
<Name>1/2 in Pilkington single glazing</Name>
<Description>1/2 in (12 mm) Pilkington single glazing</Description>
<U-value unit="WPerSquareMeterK">3.6912</U-value>
<SolarHeatGainCoeff unit="Fraction" solarIncidentAngle="0">0.81</SolarHeatGainCoeff>
<SolarHeatGainCoeff unit="Fraction" solarIncidentAngle="40">0.80</SolarHeatGainCoeff>
<SolarHeatGainCoeff unit="Fraction" solarIncidentAngle="50">0.78</SolarHeatGainCoeff>
<SolarHeatGainCoeff unit="Fraction" solarIncidentAngle="60">0.73</SolarHeatGainCoeff>
<SolarHeatGainCoeff unit="Fraction" solarIncidentAngle="70">0.62</SolarHeatGainCoeff>
<SolarHeatGainCoeff unit="Fraction" solarIncidentAngle="80">0.39</SolarHeatGainCoeff>
<SolarHeatGainCoeff unit="Fraction">0.</SolarHeatGainCoeff>
<Transmittance unit="Fraction" type="Visible">0.88</Transmittance>
The Solar Heat Gain Coeff value is missing. There is probably other missing values that I have not found.
The reason I found out of this is because in Denmark we use much better u-values that is available in the Construction.xml file. Therefore I have created new values to make it possible to use the detailed energy analysis in Revit.
