Material takeoff: As paint and other related calculations
What might be false there?
Thank you for the help,
Best
Jamal
Many thanks for the elaboration.
My issue here is to calculate the volume and area (horizontal and vertical) of each layer of the wall.
For example,
What is horizontal area of the plaster board? (Should be 0.02*length)
What is the vertical area of the plaster board? (Should be length*3)
What is the volume of the plaster board? (Should be 0.02*length *3)
How these calculations can be obtained automatically from the Revit?
To understand the way the Revit works, I considered the simple wall below to see how the areas and volume are calculated
