I have run Revit and ADT on macBook Pro with the following results.
1. Runs on bootcamp well, no issues whatsoever.
2. Runs on parallels, but continues to ask each time for activation.
Parallels says this is an Autodesk issue. However, my MS Office asks for
activation too, but allows me to continue, but Revit and ADT will not
reactivate after your 2-3 license tries.
The issue with Parallels is to allocate the correct amount of RAM to the
Parallels VM (it is surprising under 1GB - mine at 924 MB right now).
Parallels is more unstable than BootCamp in MY experience.
David Haynes, AIA
Ideate, Inc.
www.ideateinc.com
wrote in message news:5514614@discussion.autodesk.com...
Thinking of moving to a mac + thinking of moving from ADT to revit. With
parallels and or bootcamp and the intel chip I've read that some autodesk
users are doing this. So I posted over at the Architecture 2008 (ADT 2008)
forum..... some queries about doing this.
I got this reply from David of Autodesk Support.
"Well that's untested and not supported at this time. While it may work
for you; you may also experience Licensing or Activation issues in this
setup that Autodesk cannot address effectively as it depends on the
behavior of bootcamp or parallels."
David Kurtz
Autodesk Support
Manchester, NH
So I guess the question is has anyone experience with this issue? Can revit
be installed on a mac and not have Licensing or Activation issues?
Any thoughts and or comments?
