Design Options were intended for a different purpose, but they can be used to solve this problem as an unintended side effect.
Create an Option Set (call it something like Unselectable Imports) and create a single Option in it. Select the link or import
element and Add to Option Set. You will now be unable to select the link unless you uncheck Exclude Options in the Modify tool
option bar, but you will still be able to snap to the link.
This will not work if the link was imported using Current View Only.
"clarkitekt" wrote in message news:40172968_1@newsprd01...
> Is there a way to stop Revit from trying to select a linked/imported CAD
> drawing whenever you move your mouse over it? What I have is a CAD drawing
> that I am now tracing over with column grid, etc. in Revit. When I move my
> mouse over the CAD drawing Revit highlights that object (with the box that
> bounds the entire drawing) rather than allowing me to select the grid line I
> just created. I want to trace and snap to the intersections, etc, but not
> edit or select that object.
> Thanks
