Linework tool
4 REPLIES 4
209 Views, 4 Replies
Linework tool
You can't change the linework of interior components in a wall type using
this?
Matt Dillon
Autodesk Architectural Desktop Certified Expert
View my ADT Blog "Breaking Down the Walls" at
http://www.modocrmadt.blogspot.com
4 REPLIES 4
Is this in response to the "Automatic wall disjoins" topic? If so, no. I
want certain walltypes to automatically not join into certain other
walltypes.
"Matt Dillon" wrote in message
news:5070210@discussion.autodesk.com...
this?
Matt Dillon
Nope. Nothing to do with that.
I need to change the lineweight of internal wall components in a section
view and it appears that the linework tool only works on the edge lines.
Matt Dillon
"Jay" wrote in message
news:5070224@discussion.autodesk.com...
walltypes.
this?
Matt Dillon
use the "override host layers" settings to change internal wall components.
this is found in the visibility/graphics dialog box, in the lower right
corner. Check the "cut line styles" box, and then hit the edit button to
change how they are displayed.
news:5070218@discussion.autodesk.com...
Matt Dillon
walltypes.
this?
Matt Dillon
Thanks, Scott.
That appears to have done the trick. 🙂
Matt Dillon
"Scott Davis" wrote in message
news:5070285@discussion.autodesk.com...
Matt Dillon
walltypes.
this?
Matt Dillon
Forma Design Contest
