Select the text you want to add a leader to, in the options bar across
the top you should see "add a leader" buttons. You can add as many
leaders as you like.
-Z
Geoffrey Makstutis wrote:
> This is probably something really simple, but... Is there a way to
> create just a leader line with arrowhead and no note attached?
> I've got a not with a leader and I want the note to refer to two
> different points, so I'd like to just add another leader.
> Any suggestions?
> Thanks
