Revit 2014
We have a large campus project with several project files. We created a single sheet list file that we link in the other projects so that we can maintain a live, active sheet list. I set up a filter to weed out the ASK's and some other unwanted sheets that need to show up in other sheet lists just not the main one so their "Appears in Sheet List" check boxes need to be checked.
The problem is its filtering out some sheets we DO want in the list. The filter is for the field "Discipline" and its supposed to filter to "is greater than or equal to...0". The disciplines parameter for the sheets we want to keep all start with an integer so 01, 02, 03, etc followed by a descriptor. So the complete discipline for each sheet follows this format: 01. General, 02. Civil, 03. Architecture, etc. Only the sheets for the master sheet list have anything in the "Discipline" parameter. The idea is that if its blank, it gets filtered out. But again the filter is filtering out sheets that DO have the discipline properly filled in.
Has anyone else run into this? The only way I can get the sheets to show up is to completely turn off the filter...but then all the sheets show up. Unacceptable. Please help!
Thanks in advance
Solved by shawn.p.phillips. Go to Solution.
You people are too slow...I answered my own question. I was wrong. The filter was set to "is greater than", not "is greater than or equal to" as I said above. When I changed it to the latter it fixed the problem. I don't understand why "is greater than" didn't work since one would think that a blank cell is less than '0'. It worked for almost all the other cells. There is no logic as to why certain cells were filtered out while others were not using the exact same criteria in cells with exactly the same information. Revit bug maybe??
