I renamed my interior elevations to be number - letter. (Using 8.0)Three of my tags include an extra number before the name I've given the elevation in the plan view of the tag only. All 15 of the other elevation tags are reading correctly. E.g. Elevation 6-a reads as 6-a in the file directory, 6-a on sheet and 86-a in plan view. I've tried renaming and the 8 doesn't show up to delete. I'm using the default elevation tag. What's going on? How can I fix? I'd prefer not to upgrade to 8.1 until I get this set of drawings out the door. Thank you.
