Hi ,
I was wondering if Revit supports IFC XML.
coz when i exported my revit model to IFC it exported as IFC (2x3), but it not give me an option for exporting it as a IFCXML .
It would be great if any one can point me they way to do that.
Thank you in advance,
Sundeep
Solved by alan.quinn. Go to Solution.
Currently there is no option for IFC XML. You can however export to GBXML.
I have included the Help Documentation Options below:
I have included 2 related posts on IFC below:
http://revitoped.blogspot.com/2010/04/i-speak-ifc.html
http://redbolts.com/blog/post/2010/05/20/IFC-has-no-place-in-your-Revit-BIM-workflow.aspx
Thank you,
Hi, I was wondering if there is any manipulations on revit to establish an interface to give outputs into MATLAB Simulink?
Regards
Perhaps via API. Go here for more information. http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=6364883
