In elevation, we are getting same line weights for the element which is far behind as well as the elemnt which is nearer. Is there any way to give lineweights to them or we have to do 2d annotation work for it. Please suggest.
Hi, this something not solved by the factory, the only way to do it is using the linework command manually or make a workaround to get the results. Search in the forums and you will find several ideas.
thanks , Alex
