This and other elevations have lines between new and existing walls/soffits. Joining doesn't eliminate the line. The existing wall is also in a group.
Is there any way to selectively hide an edge in an elevation?
Solved by constantin.stroescu. Go to Solution.
First ,you must be sure that the surface are trully aligned ( use Align tool - I do it in a 3d View) and the material from finishes is the same one.
If this does not work you can use , in Elevation View or in any other view , Linework Override :
Constantin Stroescu
