how do I get rid of unwanted edges in elevations
4 REPLIES 4
5071 Views, 4 Replies
This and other elevations have lines between new and existing walls/soffits.  Joining doesn't eliminate the line.  The existing wall is also in a group.
Is there any way to selectively hide an edge in an elevation?
4 REPLIES 4
constantin.stroescu
First ,you  must be sure that the surface are trully aligned ( use Align tool - I do it in a 3d View) and the material from finishes is the same one.
If this does not work you can use , in Elevation View or in any other view , Linework Override :
  • in Elevation View > Modfy > View > Linework > Linestyle > Invisible Lines > click on linnes you want to hide from view...
Constantin Stroescu
in reply to: constantin.stroescu
Thanks.  Typing LW makes a quick shorthand to get to it quickly.
shafeeqmustafakm
BUT DOING LINE WORK IN MULTISTORY BUILDING IS NOT EASY.
Thank you so much! This helped me a lot!
Forma Design Contest
