Hide decal line
11 REPLIES 11
Message 1 of 12
13692 Views, 11 Replies
Hide decal line
I am using Revit 2013 student version. I have successfully attached a decal on one of my walls and managed to show a realistic mode of the decal in my elevation. I would like to remove the decal lines (rectangle with x inside) but I am struggling to do this.
I have done some research on the web and so far, found out that I need to select the decal lines (or cross), right click and choose Override Graphics in View > By Element, and check Transparent. The problem is, my system does not display the option for Transparent; I am only given the boxes for Visible and Half-tone.
Help please.
Thanks mucho,
Ging
11 REPLIES 11
Message 2 of 12
constantin.stroescu
it is not clear for me what you do you want...is that something like in my attached image ?... or something else....
Why do you say that the X appears on your image ?  It appears only when selected...
If you want to change the border of the decal :
Modify/Generic Models>Override Graphics > Override by Element > View-Specific Element Graphics >Projection Lines > change Weight, Color , Pattern.
If you want to change the image , then go to Manage > Decal Types >select the de Decal from the list and you have there a lot of settings
Constantin Stroescu
Message 3 of 12
constantin.stroescu
sorry ...I forgot the attachement...
Constantin Stroescu
Message 4 of 12
in reply to: constantin.stroescu
Hi Constantin,
Thank you for your reply and SO sorry for this late reply (a year later!). I suddenly found myself not having to use Revit after I posted my query last year, Now I'm back!
I attach three files:
1. Apple: the black rectangle around the apple is being formed by the decal. These are the lines I want to get rid of.
2. Apple projections lines: I tried what you suggested but I couldn't find a setting for a transparent line. I tried using white but it just cut the leaf part of the apple at the top.
3. Apple properties: I thought it may be useful to attach an image of the decal properties here.
I hope you're still able to help, i.e., after a year of my silence!
Many thanks,
Ging
Message 5 of 12
There is no transparent line.....you need to override by element and change the projection lines to white or the color to match your background. There isn't a way to hide them totally for some reason anymore. It gets a bit more difficult if it's against a multi-color background though.
Message 6 of 12
Constantin you are a real legend your methods of explaining has helped me immensely.
Thank you thank you thank you!
Message 7 of 12
Hey! Just wondering if anyone has ideas on how to solve this specific problem with regards to hiding the decal line... I have changed the projection lines to white but they still show so much! Is this just the best it can be in Revit?? Thanks for any help. Screenshot 2021-03-19 151646.jpg
Message 8 of 12
brookeHVFCJ
Hi All,
Hopefully this might help someone in future. This is how I removed the decal boarder lines for my realistic views in revit. Currently working in Revit 2022.
  1. Create a filter by accessing Visibility/Graphic Overrides, under the Filter tab and selecting Edit/New.brookeHVFCJ_0-1659664196770.png
  2. Once the Filters window has opened, select New and add a name.brookeHVFCJ_1-1659664255688.png
  3. Copy the below settings for the Filter and select OK.brookeHVFCJ_2-1659664304644.png
  4. Back in the Filters tab in Visibility Graphics select Add, then select the created filter and press OK.brookeHVFCJ_4-1659664381863.png
  5. The Filter will appear in the Filters tab in Visibility Graphics. Uncheck the tick box under Visibility. Press Apply and OK and the decal boarder lines should disappear.brookeHVFCJ_5-1659664414283.png
The below link is also a great video of how do manage decals on glazed surfaces.
https://www.youtube.com/watch?v=gyFw4PTQeag&list=PL7uMJuKCAISolrOH5brZBvSMbMO9PjSOr&index=26
Message 9 of 12
rcaddellZFC7B
in reply to: brookeHVFCJ
Didn't expect it to work, but it definitely did!
Message 10 of 12
Many thanks for that solution. It certainly worked!
Message 11 of 12
This worked very quickly! 😉 TY
Message 12 of 12
LNomesque
thankyou! this worked!
Forma Design Contest
