Roger Helgesen wrote:
> Is there a template for this ?
Yes and no. If you don't have a template for what you want, you can
always start with a generic template and then under Family Categories
on the settings bar change it to be in the desired Category. It's
quite flexible, actually.
So start with the 'floor hosted Generic Family' template, and then
model/draw/whatever your floor-mount plumbing fixture, then set it's
category to 'Plumbing Fixture' and save it out to your library. Revit
will make it behave as both a floor hosted element and a plumbing
fixture when it's loaded into a project.
hope this helps!
Jeffrey McGrew
Application Specialist BSD
AEC Technologies, a division of ID8 Media Inc.
(415) 593-6000 x 129
(415) 593-3333 Fax
(415) 505-4689 Cell
www.aectech.com
www.id8media.com
