I have a Multi-Category Schedule and using certain fields it shows me Furniture, Toilet Assoc., Plumbing Fixturers, etc. All I want the Schedule to show is Furniture and Furniture Systems together in one schedule. When going to the Filter I choose Category>Equals>Furniture Systems and Category>Equals>Furniture. Assuming that the schdule would filter out everything else and only show items from the Furniture Systems Category and the Furniture Category. Instead it shows me nothing, eveything disappears. Its as if it is looking for a Catgory that is botn Furnitue Sysems and Furiture as one. I can do each Category individualy and its fine but I can't Filter by both? How can I get this scheudle to just show me Furniture and Funiture Systems? Or, what am I doiong wrong? Or is their an update to correct a bug in the software that will fix this?
Thanks!
Solved by CoreyDaun. Go to Solution.
All of the conditions are related by an "AND" operator, not an "OR". This means that by the conditions you have defined, an element would have to belong to both the Furniture Category AND and the Furniture Systems Category at the same time, which is impossible and why your Schedule is blank. Instead, set your Filter Rules to match the image below.
In case the image above is not available, there are two Filter Rules set; both are set to filter by Category, but one is set to "is greater than or equal to" "Furniture", and the other is set to "is less than or equal to" "Furniture Systems".
