It usually happens when there are many views, don't have an exact figure,
but its more than 10. In the properties of the rectangles, they are called
"viewports", but I can't enter model space through them, the model doesn't
show up within them, etc.
"E L S"
wrote in message
news:5062878@discussion.autodesk.com...
Does it occur when there are many viewports? Are you sure they are
rectangles (ploylines) in ACAD? Reason I ask is ther is a system
variable in AutoCAD to control how many viewports will regenerate.
Maxactvp (I believe) is the system variable.
Other than that, I dont have a clue.
Jay wrote:
> Occasionally, when I export a sheet w/ multiple views to dwg, some of the
> viewports come correctly, and some end up as rectangles in paper space,
> not
> as viewports. How can I fix this?
