I have a error that pops up on several different projects:
"The linked files listed below could not be located. They will be displayed as they were when this project was last saved. You can use Manage Links to correct their paths."
The problem is that the file is there correctly, I have reloaded and reloaded from, copied and renamed the file, tried a different folder, tried the make the path absolute, tried to save the location; but nothing works.
Deleting the link and reinserting/linking is NOT an option (too many views reference the file and each has different VG settings - I'm not about to redo all that work!)
Any suggestions?
