sparrowitis wrote:
> I have tried to create a curtain wall by duplicating an existing curtain wall, but unlike the regular walls, I cannot edit the structure of the curtain walls. Any further suggestions?
Yeah, curtain panels are a separate family. But now in Revit 7 you can
use normal wall types as a curtain panel. So the really simple way to
do what you're looking for is to first make a new basic wall type
called 'Dbl Glazing' or something, make it 'glass-void-glass' within
the wall construction parameters, and then after you've drawn your
curtain wall select the panels and swap them for that wall type...
Jeffrey
