Found it. Next ?: Can you set the "to room" regardless of the swing
direction. ie: a door between a bedroom and closet, schedule should only
say closet, but door might swing out into the bedroom for a regular closet,
but into a walk-in closet.
"Jay" wrote in message
news:5255019@discussion.autodesk.com...
Where do you get these parameters from? Are you using shared parameters in
the door families?
wrote in message news:5192350@discussion.autodesk.com...
No, but in your door schedule you can add the fields from room and to room,
then just modify the number from teh schedule to match the room
