Can you post an image? Images can help a lot.
Can you take a snapshot of the plan view of the elevation marker with the boundary highlight and the elevation view.
Is the depth of the elevation marker going beyond the wall? Is there anything in front of the windows to block the view? (I am figuring there isn't but never hurts to check)
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
