DIMENSIONS IN 3D
0 REPLIES 0
Message 1 of 1
200 Views, 0 Replies
DIMENSIONS IN 3D
Hi
Im having a problem with placing some dimensions.
I have a 3D stick diagram of structural element centre lines created in autocad, I  was going to replicate the linework in the massing family to then use it to set out the structure. i.e xy coord and a level then the radius and the centre point.
In the massing environment it will allow me to place radial dimensions in 3D but they dont show through when you close the editor.
Is there a way of making them show through and can i use the centrepoint to set out an x,y and z coordinate?
Please see image.
Thanks in advance. Bit crazy i know.
0 REPLIES 0
Forma Design Contest
