If you have all the lines for the cutouts in position on the wall, select
the lines, Control X (or C) the lines, select the wall, "Edit profile", then
"edit" "paste aligned" "current view" then "Finish sketch: and you're done.
Chris.
Architecture DM Northland
Whangarei.
New Zealand.
wrote in message news:5711407@discussion.autodesk.com...
I am working on a very large Metal Screen that is Approx. 55'-0" H x 240'-0"
W.
I need to create the actual punched screen for my Revit Model Renderings and
can not use a decal as an option. Each 4'x8' panel will be punched based on
a Raster image that I have created an algorithm the convert the image to a
Vector Autocad file so the metal fabricator can program the puncher. Every
panel is different and thus can not be created and just copied over the
entire screen.
The only way I have been able to attempt creating this screen hase been to
Edit the profile of a wall. this method though is insanely time comsumming
and not really an option unless someone can tell me how to select all the
lines brought in from cad together and edit. I have only been able to click
individual lines...
I am attaching 2 DWG files, one that is off a full size portion of the
screen and one that represents one panel (approx. 4' 8').
I am also attaching a RVT file that has the DWG brought in an placed on on
elevation of the "wall".
PLEASE HELP!!!!!
