How do I place a call-out only without head, tail, or anything else? Currently I have to create a Detail Call-out and stretch the boundary to a very small rectangle so it won't show up when print. And I don't want fake call-outs that don't link.
Thanks a lot.
One approach could be as follows:
1. Manage > Additional Settings > Callout Tags > Duplicate > Name accordingly
2. Set Callout Head > None, OK
3. Add Detail Callout > Select > Edit Type > Duplicate > Name accordingly > Set Callout Tag > new type
4. This will remove head geometry, and then you could simply hide the dashed callout line by element in the view:
Video Example: http://screencast.com/t/tc1EgxRlh
Hope this helps, thank you,
What if I wanted to create a new callout tag that can be placed (separately) at the end of a line of text. Such as: Refer to Detail 10 / A501 How would I modify a reference tag to make it work like this?
Thanks!
This is the one I use. When you are in a view, go to "View, Sheet Composition" and choose "View Reference" to use this as a free-standing view reference. It is separate from the text string, so if you add text, you'll need to move the reference over.
Then once you click the button, the green status bar offers you a drop-down for selecting other views you'd like to reference. Hope this helps!
