Show only
Search instead for
I am trying to load the dimension lumber and timber lumber from the structure family. After I select it the load pulldown does not show it anywhere. Is there another folder I should look at? Thank you in advance.
Are you loading the detail components? If so they will show up under the drafting toolbar/components. If you are loading true struct. families, they will show up either when you click beam, col. or framing from the structural toolbar.
