How can I change the default top constraint for all my walls!
Some are by default constraint to the first floor, others are unconnected! That makes me think I can change it! ... But how??
I beleive when you place a wall and make constraint changes in the property panel it rembers that change the next time you place a wall. The changes must be made prior to placing the wall. Hope this helps.
Yeah I thought so too. It was the first thing that I tried. Does it work for you? It does work for me unfortunatly!
