I have a student license and successfully downloaded and used Revit 2014 for a few months. I need to update to 2015 for my school files. I deleted Revit 2014 and all it's components from my computer. I have tried unsuccessfully to download Revit 2015 three times. I have copied the log file below...Any suggestions??
2014/11/12:16:34:45 Karli K KARLI Installing Autodesk® Revit® 2015 Language Pack: TRANSFORMS="C:\Users\KARLIK~1\AppData\Local\Temp\_AI43D4.tmp\_laEC56.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/12:16:35:18 Karli K KARLI Install Autodesk® Revit® 2015 Language Pack Succeeded
2014/11/12:16:35:19 Karli K KARLI Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/12:16:35:27 Karli K KARLI Install Autodesk Workflows 2015 Succeeded
2014/11/12:16:35:28 Karli K KARLI Download Skipped CM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CM2015.tar...
2014/11/12:16:35:28 Karli K KARLI Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/12:16:36:35 Karli K KARLI Install Autodesk Material Library 2015 Succeeded
2014/11/12:16:36:35 Karli K KARLI Download Skipped CMILB2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILB2015....
2014/11/12:16:36:35 Karli K KARLI Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/12:16:37:15 Karli K KARLI Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/11/12:16:37:15 Karli K KARLI Download Play CMILL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILL2015....
2014/11/12:16:53:19 Karli K KARLI Download Aborted CMILL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILL2015....
2014/11/12:16:53:19 Karli K KARLI Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/11/12:16:54:34 Karli K KARLI Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/11/12:16:56:01 Karli K KARLI Rollback Autodesk Material Library 2015 Succeeded
2014/11/12:16:56:07 Karli K KARLI Rollback Autodesk Workflows 2015 Succeeded
2014/11/12:16:56:42 Karli K KARLI Rollback Autodesk® Revit® 2015 Language Pack Succeeded
2014/11/12:17:05:08 Karli K KARLI Rollback Autodesk® Revit® 2015 Succeeded
2014/11/12:17:07:31 Karli K KARLI Rollback Autodesk® Revit® Content Libraries 2015 Succeeded
2014/11/12:17:07:31 Karli K KARLI Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619
2014/11/12:17:07:32 Karli K KARLI Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2014/11/12:17:07:32 Karli K KARLI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/11/12:17:07:32 Karli K KARLI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/11/12:17:07:32 Karli K KARLI Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/11/12:17:07:33 Karli K KARLI Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/11/12:17:07:33 Karli K KARLI Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/11/12:17:07:33 Karli K KARLI Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
hi , you can try this if you want to?
Please ensure the following has been done:
1. Computer meets the minimum requirements
2. UAC off
3. Firewall off
4. Anti-Virus off
5. Administrator rights
6. Clear the temp folder
7. Make sure you have enough disc space 60 Gigs at least
8. Make sure the OS is up to date
9. Reinstall C++ redistributable
10. Reinstall .Net Framework
11. Copy the content of the installation media to the C drive. Preferably on the root of the C drive to negate the problem of filenames becoming too long
12. Make sure short file name creation has been enabled HKEY_LOCAL_MACHINE\SYSTEM\
CurrentControlSet\Control\FileSystem Set NtfsDisable8dot3NameCreation to a value of 0
13. Create a new Windows user with full admin rights
14. If the computer is on a domain remove it from the network completely for the duration of installation
