Revit Architecture 2011.
Problem: a drawn beam isn't visible / selectable.
Steps I took:
Structure > Beam > selected a beam > on first floor plan
Section shows the drawn beam. However I can't selected / move /see the beam.
The beam is below the first floor so that I can't see the beam is logical to me.
When I go to the level below (basement) I don't see any dotted lines indicating a beam above it. And again the beam can't be selected.
My questions:
* how do you work with beams in Revit (adepting vis.settings everytime?)
* how does Revit show beams above the cutlevel (a dotted line). If not standard: is there a workaround?
Kind regards,
3Pinter
love python coding
