if you insert a DWG with a hatch pattern into Revit, the hatch becomes a
Filled Region pattern. Put them in your template to have available to new
projects.
You can also add the text to the revit.pat file, located typically in
C:\Program Files\Autodesk Revit Building 9.1\Data
Read the intro in the Revit.pat file carefully....you must make some changes
to autocad hatch patterns to make them either drafting of model patterns in
Revit.
wrote in message news:5424525@discussion.autodesk.com...
Okay, so I was missing them.
I'm hoping that since revit is autodesk, I could copy autocad patterns into
revit? if so.. where do they go?
