I'm getting an error message that I don’t fully understand when using an adaptive component. "There is only one component in this repeater" I am trying to create a undulating ceiling and attach an adaptive "Rafter" to follow the form. I can occasionally get it to work but on occasion I receive the error message. I can send you the file if you like, I’m pretty sure it’s a “User Issue”!RAC 2013
I have been told that it is to do with the direction that I draw the curves but I would like a more indepth explanation of this error...
The other issue I'm having may have to do with the placement of the adaptive component on the node plane, depending on where I place the component it will change the orientation if the rafter...
Solved by scott.chatterton. Go to Solution.
Select the divided path, and see its properties. There might be a combination of settings that is not producing a logical result, maybe the distance between objects, maybe the number of objects, maybe the indent values, all this, in relation to the length of the path, might not be making sense.
About the orientation of the repeater, you might need to set the family that repeats to be "always vertical". If the path has adaptive points, check the Orientation parameter of those points in regards to placement; sometimes you need the points to be "orthogonal", sometimes "vertical", etc.
Ahh, thanks. Yes I played with the "Always Vertical" which is nice to know but not applicable for this particular application. I'll look at the parameter orientation... thnks again, looks like I'm on the right track!
Sc
