I have a problem with accented capitals...
Instead of seeing " Â " (on screen and printed), I get " Á "...
the problem is only in Revit, nowhere else... when using "text annotations"
Hi. Not sure if this helps but try it.
Go to the start menu and type char, choose the character map, and make sure that the shortcut you're using will give what you're looking for.
If I misunderstood please let me know.
Hi. I created various different characters and everything appeared fine. Maybe it has to do with graphics or compatablility. Good Luck.
