Hi,i what to acomodate some 3D views on a sheet, but the problem is that i dont have control of the scale that i need them or if there is any method of doing it i don't know how to do it. can somebody help me on it?.
here is the link of an image of what im talking about:http://screencast.com/t/mFkFRThm
thanks.
Solved by arunag. Go to Solution.
These are the camera views hence no scale.In sheet select the view, go to size crop in the ribbon, you will find the option to change the scale or the field of view proportionately which will increase or dicrease the size of the view.
