Walls partially disappear when zooming in
9 REPLIES 9
Message 1 of 10
MARKOL2706
279 Views, 9 Replies
Does anyone know why the walls would disappear when zooming in? Making it hard to draw because I can't see where I've already drawn when zoomed in.
EDIT: occuring in level 2 of attached file
Labels (4)
9 REPLIES 9
Message 2 of 10
in reply to: MARKOL2706
Set your View Phase Filter to Show Complete.
Message 3 of 10
MARKOL2706
in reply to: barthbradley
Thank you for the reply. This still is having the same effect after changing the phase filter.
Message 4 of 10
Use Hidden Line mode.
...just checked.  Your View Visual Style is indeed set to Wireframe.  Set it to Hidden Line.  If that doesn't work for you, then I suspect the Link is affecting the display. Don't know for sure though because I don't have the Link.
Message 5 of 10
Do you mean the CAD Import's solid hatch covering the Revit walls?  I don't experience the same thing as you said, but you can do one of the few of things in order to see both Revit walls and CAD solid hatch:
- disable hardware accelerations
- override the CAD import to have some transparency, keep the view as wireframe as you have it
- set the view to Hidden and override walls category to have some transparency
- when link the DWG, tick the box Current View Only, then you can set the DWG to Background or Foreground
Message 6 of 10
You're talking about this; correct?
...with Hidden Lines:
Message 7 of 10
MARKOL2706
in reply to: ToanDN
I am able to see the CAD Import with no issues. The Revit walls I am drawing over top of the CAD import are the ones that keep seeming to glitch. I did override the walls category in view to halftone and show pink. Hardware acceleration is disabled in my settings.
Message 8 of 10
MARKOL2706
Yes. Correct, they show up missing sections when zooming in/out and moving around.
Message 9 of 10
MARKOL2706
This fixed my error. Thank you so much. I'm still learning so I keep forgetting simple things like this.
Message 10 of 10
MARKOL2706
in reply to: ToanDN
Thank you for the advice. This will help me moving forward. Great trick/tip.
Autodesk Customer Advisory Groups
