so I select uncut geometry
select the solid
select the void
solid disapears
void is left
that is such a repetative result it makes me wannt throw Revit out of the window...
is there anyway to make the now invisible to deleted solid apear?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
I believe I can reproduce what you are seeing, but it seems to be dependent on the shape of the solid/void.
If it’s the same issue I’m seeing, changing the Detail Level clears the issue (as well as closing and reopening the file).
If the issue you are seeing is the same as the one I reproduced, then this has been logged with our developers, and you can restore the display by changing the detail level (and then back).
Claas Kuhnen
