Structural Beam Systems Display Issues
7 REPLIES 7
Message 1 of 8
10823 Views, 7 Replies
I am using Revit 2013.  I have inserted a structural beam system (SBS).  It seems to be created correctly, although I can only see it if i hover ovr it.  I have read the other posts about this being a view range setting.  I played with the view range and still no luck.  I eaven moved my beams above my floor level by a foot and they still do not show.
The other issue I am having is that the only display that I get from the SBS is a dashed line.  I have set the beam type to a Plywood Web Joist:1-3/4x11-7/8, that I brought in from the OOTB families directory.  I can insert these and they display just fine with the beam tool, both below and above the cut plane.  I am wondering if something is not working correctly with my SBS tool
Any insight into this issue would be most helpful and place you on Santa's nice list.
Darek
7 REPLIES 7
Message 2 of 8
Try applying a View Template called Structural Framing Plan--there should be one in the list under View>View Template Manage View Templates. Make sure to set the Discipline to Structural when selecting the View Template.
( It could be a Coarse/Medium/Fine detail in the view setting. )
This usually corrects the problem.
Message 3 of 8
I wish that it would have been that easy.  I can't even see the beam in a 3d view.  BTW when I switched to the Structural Framing Plan view template and set the discipline to structural the only thing i can see is my floor slab and stairs, everything else disappeared.  Currently my SBS is set to an elevation 12" above my floor slab.
I'm at a loss here ...
Darek
Message 4 of 8
Above the slab? Normally beam systems are placed below the slab. Perhaps that is why you are not seeing it.
Can you copy just the slab and beam system out to a new file and post it here?
Message 5 of 8
I moved the SBS all over the place to try and get it to be visible.  No such luck yet.  The interesting this is that if I place a beam using the beam command it displays just as one would suspect, in plan, 3D and sections views.
Very odd behavior but I will figure this out.
Darek
Message 6 of 8
I have just had this issue. THE PROBLEM IS THAT THE TOOL IS GLITCHY! Thanks Autodesk. C'mon work it out. Basically it depends on the sketch lines. I redrew the beam system with a fresh set of lines in the same shape as the first time and it worked. The only thing that was different in my case was that I didn't use copy paste (from the roof shape above) to place the sketch lines. I started fresh!
Message 7 of 8
deshappriya.thilan
Your Detail level should be at "Fine" level. You can find it next to visual styles box. Then you will see the Beam system as it is.
Message 8 of 8
in reply to: deshappriya.thilan
Thanks!
