spliting saircase
1 REPLY 1
133 Views, 1 Reply
spliting saircase
I need to make a staircase that starts with two separate runs in opposite direction that meet on a platform and continue up with one run.
1 REPLY 1
You'll want to make three (separate) stairs then, one for each bottom run up to the platform, and then the one that goes up from there. By setting the levels and the Offsets correctly, this shouldn't be too hard.
You might want to use a floor for the platform as well in this case, instead of having it be part of the stairs.
