Ribbon Behavoir Revit LT 2013 following Revit LT 2014 install
9 REPLIES 9
Message 1 of 10
p.day
1080 Views, 9 Replies
Hi
I have just installed Revit LT 2014 and now the contextural tab when editing or creating a floor for example no longer appears. (No red X, green tick or lines)  This appears to be a similar issue that happened with Revit architecture 2012 when .Net4.5 is loaded.
Does any one know of a fix. I need to be able to continue running 2103.
9 REPLIES 9
Message 2 of 10
scott_d_davis
in reply to: p.day
yes, make sure you are running the latest version of Revit 2013 SP2. There is also a hotfix available by searching on Autodesk.com
Scott D Davis
Sr AEC Technical Specialist
Message 3 of 10
masurawo
in reply to: scott_d_davis
I cannot find a hotfix of Revit LT 2013.
Please teach me Direct URL.
Message 4 of 10
p.day
in reply to: masurawo
HI
Likewise I couldn't find any hotfix mentioned in earlier post.
Due to time restrictions I ended up having to remove LT 2014 and revert
to 2013 only. I will have to investigate further at a later time.
regards
Paul Day
on Behalf of Marson Rathbone Taylor
The information contained in this communication is STRICTLY CONFIDENTIAL and may be legally privileged. If you have received it in error, any disclosure or copying of all or any part of the contents is prohibited.
T 01789 292383
F 01789 292012
E Office@mrtarchitects.co.uk
I www.mrtarchitects.co.uk
Message 5 of 10
Joe.Charpentier
More details on this issue (including download links) here:
http://revitclinic.typepad.com/my_weblog/2012/05/revit-2013-2012-contextual-panels-do-not-display-or...
The root cause is installing .NET4.5 (which Revit 2014 uses) but you might see this in other situations.
Note there is no hotfix for r2013, only for r2012.  For r2013, to get the UR, you simply have to launch the updater from communication center (the satellite dish in the upper-right corner)
There is a hotfix for r2012:
http://revitclinic.typepad.com/my_weblog/2013/03/revit-2012-hotfix-available-for-net-45-contextual-t...
Joe
Message 6 of 10
where?
Message 7 of 10
DarrenP
in reply to: eddierocketship
where what?
DarrenP
Message 8 of 10
eddierocketship
in reply to: DarrenP
Where what what?! You alluded to there being a fix for the Revit LT 2013 ribbon... where is it on Autodesk.com? There is one for Revit 2013, not Revit LT 2013.
Message 9 of 10
bcarriere
For some reason Revit users think Revit service packs and hot fixes apply to Revit LT and they do not!
Message 10 of 10
Alisder.Brown
in reply to: p.day
Installing the 2013 service packs 1 & 2 fixed the issue for me in both LT and full Revit.
Update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121970&linkID=9273944
Update 2: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679231&linkID=9273944
Have a read of this Link:
 http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Revit-2014-Corrupts-Revit-2012-and-2013-Ri...
 fixed the issue on all the workstations in my office running 2013 when 2014 was installed.
Regards
Alisder Brown
Senior BIM Coordinator
Scotland, UK
