Revit Architecture Not Printing to Scale
3 REPLIES 3
534 Views, 3 Replies
I just recently noticed that when I print documents from Revit Architecture, they are printing smaller than the scale size they are set to. I verified with a couple of different scale settings against a good old fashioned scale ruler. It seems to be consistently incorrect.
Any idea what's going on?
3 REPLIES 3
constantin.stroescu
does your settings look like here ? Zoom=100
Constantin Stroescu
Wlecome to the discussion group. Not sure what settings you are using. Make sure under setup, the zoom button is selected and that it is set to 100% size. If you are printing a sheet, the appropriate size sheet that matches your title block has been selected. That's pretty much it.
Just tried it. That was the problem and it now works perfectly. Thanks so much!
Autodesk Customer Advisory Groups
