- Mute
- Permalink
- Report
We have installed Revit 2016 R2 on three of our Office computers. When attempting to synchronize with central revit just spins away and will not finish the process. This does not happen every time we STC but it does happen on all three computers. If you click anywhere on the screen the revit window goes blank - Revit not Responding. Only way to proceed is to close revit down and restart. Each time this occurs Revit creates a dump file IN THE PROJECT FOLDER ON THE SERVER (not in the normal folder where journal files are stored). It doesn't matter which user gets the crash the dump file is always for worker #1 (journal.0006.worker1.0001.dmp) though if you look at the properies of the file > details the name of the user will display.
We wiped the R2 version from one of the three computers and re-installed the earlier version of 2016 and the crashes stopped. Anyone else having this problem? Anyone with a solution?
