Good day all,
When attempting to save out to a central model, Revit 15 throws an error "A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects. Would you like to save a recovery file?" then completely shuts down the program.
The central model is stored on an inhouse project server; Although Revit server is on the network, it is 2013 and NOT being used to sync between the architects for this particular project.
The workstations have 32GB of RAM, 2TB hdd space, OS is Windows 7 (fully updated). We have installed the Revit 15 updates, too. The crash still occurs on more than one workstation.
Attached is a copy of the journal with logs leading up to the most recent crash.
Thanks in advance for any clues to help fix this problem.
Looks like a Purge Unused was done shortly before attempting the SwC. I also see 3300+ worksets getting deleted which would potentially correspond with purging a lot of families from the project.
Try opening the most recent backup of the project and using SwC, prior to the purging happening. Also try closing worksets associated with linked files or unloading them prior to using SwC to rule out interactions with them as contributing to it.
