missing project browser.view tab is checked and i dont use dual screen and i also deleted UIState.dat.
Solved by didemseren. Go to Solution.
Hi @didemseren
I see that you are a new visitor. Welcome to the Revit Architecture community!
Which version of Revit are you using? Can you try a repair of Revit and see if this helps?
Also, check if you have the latest updates installed for your Revit version from your Autodesk Desktop App.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Try:
View Tab>User Interface>Check then uncheck, then re-check Project Browser.
If this doesn't work, see if the Project Browser is "hiding" behind another window.
I cahnged the display settings from low resolution to recommended and now it is done. Thank you for your advice.
project broswer is missing i need your help plesse contact this mail infome
Hi @danish598
Welcome to the community!
Did you try the recommendations mentioned above?
What version of Revit are you using? Can you check if you have the latest updates installed?
Viveka CD
How do you know the browser is hiding behind something. I can get all the browsers to show except properties and project browser which i moved yesterday after a Zoom
Hi this is Louis. I am new to Revit. I am using 2022. Every time I try to engage browser, the "modify" button jumps but I cannot get behind it. Can I reinstall Revit without losing any files?
I have the same isue now. Properties and project browser are gone and I can't get them back on screen.
Not by going through user interface or right click on the screen. The Modify button flashes but the browsers don't show up.
What to do?
