Problems with self created window!
4 REPLIES 4
364 Views, 4 Replies
i created the window attached below. Everything is working fine, except that the little triangle above has no glas?
If i insert the family into my project, the three big windows have glas, the triangle not. In the family editor, glas is shown.
What is wrong?
4 REPLIES 4
L.Maas
In the project set the detail level from fine to medium, and those triangles will show up.
Louis
Please mention Revit version, especially when uploading Revit files.
in reply to: L.Maas
Hmm i tryed it.
If i view the window integrated in my building in 3D mode i cannot see a glas in "detailed" view (triangle window). Only in the other detail mode i can see one, but i need the detailed view!
Why is the glas missing in detailed 3D view?
L.Maas
I selected the triangle window in the family editor and activated the visbility settings
You can see that Fine (detailed) is not selected.
Louis
in reply to: L.Maas
Solved! Thank you very much!
