Need Help!!! Revit 2011 won't start!!
4 REPLIES 4
578 Views, 4 Replies
I've tried to remove this file and it does not apperar in the folder
c:\Documents and Settings\%USERNAME%\Local Settings\Application Data\Autodesk\Revit\Autodesk Revit Architecture 2010\ENU\Components\WebServices\WSCommCntrData.xm
I also deleted the webclient folder from the registry and nothing.
My processor supports SSE2 instructions too!!!!!
Any other ideas????
4 REPLIES 4
Sorry sir,
I was going to try and offer a useful suggestion like make sure your license hasn't expired, but after reading your post, I have not idea what the he** you're talking about. But I'm not really an IT guy. Unless this is a dialog that's already in process with others more knowledgeable about such things, perhaps you could provide a bit of back ground and context.
Good luck.
OK. I intalled revit 2011 and it won't pass the splash screen. It crashes after it appears.
My hunch is that there is either something currupted in the installation of the software, or you have a hardware issue (as in dammaged or incompatible components). Obviously Revit isn't supposed to do this. You might also look into security software issues or viruses.
Sorry I can't be of more help. Good luck.
Shawn Graham
Designer.
DarrenP
try this: http://revitclinic.typepad.com/my_weblog/2010/10/scripting-revit-2011-hang-at-splash-screen.html?utm...
DarrenP
