Meandering pathway
2 REPLIES 2
158 Views, 2 Replies
Meandering pathway
Is there any easy way to draw a pathway, that meanders right & left and at the same time, undulates up & down? I've been trying to do it with a toposurface and it always seems to add sections of surface that I don't want.
Lee
2 REPLIES 2
Create your topo surface much larger than your path, with the slope you are after. then use the split surface tool(not subregion) to cut out your path, then delete the unwanted topo.
Worked great, thanks for the help.
