loosing the + (plus) sign
4 REPLIES 4
dgizzim0
988 Views, 4 Replies
Why after long hours of work, the plus sign in the project browser disappears. The only cure for this is to exit Revit and open Revit. After extended use, I close hidden windows and this still happens.
Any cures?
4 REPLIES 4
rosskirby
in reply to: dgizzim0
Don't work such long hours.Smiley Happy
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Alfredo_Medina
in reply to: rosskirby
Haha... I agree. I think you and your Revit need some rest.
It's the first time I read about plus symbols vanishing from the project browser.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
loboarch
I saw this quite frequently back in Revit 8, 8.1 and 9.  I have not seen it happen in quite some time.  I believe it is caused by low resources on the machine.
PCs and different applications can have "memory leaks" that rob the system of resources over time.  Exiting and restarting the application will resolve the problem.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
I saw that happen in some of the previous releases as well. Then I was working with Windows XP Prof 32bit. Have not seen it while working in 2010 or 2011 on Windows 7 pro -64 bit. At least yet.
