Dear All,
As can be seen from the attached image I couldn't get the linked Revit file to show the levels, even though that I'm sure that all the levels in linked file are intersecting with section line, still I'm missing that symbol for levels especially for level +4.00. Your guidance will be appreciated.
Solved by barthbradley. Go to Solution.
Use the Copy/Monitor tool to Copy the Link's Levels to your Parent Project and then hide the Link's Levels in all the Parent Project Views.
