Hello Everyone,
I've same problem for Cad link.
I want to bring cad file to background in this case i've tried 2 method
1. Cad file as import, but not shown "Draw layer" in Properties Palette.
2.Cad file as link but still not show any option to make this cad file into background or foreground (in properties or option bar)
please help me
thank you all.
It's the other way round I'm afraid. Imported CAD can be switched from foreground to background, linked CAD can't, even if it is pasted in "current view only"
I apologize, a linked CAD can be switched from background to foreground just like an imported CAD providing it's linked in "current view only" mode, just like it was mentioned. Thanks
Is there anwyay to have a CAD file that is a model object set to 100% transparancy. We like to put our CAD files into 3D space, but they end up covering up 3D elements.
Yes.
Link it in another Revit project file. Link that Revit file in your Revit file and set the link to Underlay in VGO.
@dmaughan25 wrote:
Thanks. Can you still hide a single instance of one of the linked CAD files in the revit file you are brining it into? For instance there may be mutliple CAD instances in the revit linked model but I only want to hide one of them in a view.
Yes. You can TAB and hide selected CAD instance in the link. If you can't then hit back.
Just insert the cad into a new drafting view and Copy and paste where ever you want,
