What is the best way to attach a vertical face between the two parts of the roof shown in the attached picture (so that there is no hole in the roof)
Any advice would be helpful
Are you asking about how to close the face of the Gable? not sure what you're aksing for?
Can you please give some more specifics?
Mike
You could just create a wall type of "At Least" you finish material, add it in place a a levet above your top plate line, or even create a "level" just below the top of the lowwer roof and set the wall to it. Then "edit Profile" of the wall to match to pitch of the roof.
Mike
