Hi everyone,
I have a level for the structural foundation which lays -800mm below the ground floor.
But I don´t want to show that it says -800 because it can vary if the ground is not stable enough.
So what i want to do is override -800 with text that says - Foundation on stable ground.
Can anyone help me with this?
Thanks anyway.
Solved by loboarch. Go to Solution.
You could edit the family to not have the elevation label and replace the label in the family with the required text. Then load back into the project and create a new level type that uses the alternate Level Head Family.
You can create new level head family, where is no elevtion tag, only text.
